Will a P0A ECU work with an H22A?
Old Nov 3, 2012 | 04:48 AM
TNM857's Avatar
Default Will a P0A ECU work with an H22A?
I have a P0A-Y01 ECU from my 94 Accord EX (F22B1 engine).
I plan to have an H22A swap. Will my P0A ECU work with the H22A?
Any help/advice would be greatly appreciated.
Old Nov 17, 2012 | 05:38 AM
holmesnmanny's Avatar
No it will not. You will need an h22a or h22a1 ecu. Remember you need to swap your A6 and A11 pins at your ecu connectors when you plug the h22a(1) ecu in. Those pins are different on your car than on the h22a.
Old Nov 17, 2012 | 06:17 AM
I agree with the other user, it will not. They are not that expensive to buy though. Just ebay search a p13 obd1 ecu.
Old Nov 18, 2012 | 11:28 AM
TNM857's Avatar
Oh dear. They are quite expensive here (I'm from the Philippines).
So the best ECU would be an OBDI P13? The engine I am going to get is an OBDII. Will it work? Or do I need to do that wiring thing?
Old Nov 18, 2012 | 11:31 AM
Your car is obd1, you will want a obd1 ecu, it will work fine with the obd2 engine.
Can you buy one from a US seller and have it shipped? I don't think I've ever paid more than $100USD or so for one.
Old Nov 19, 2012 | 12:53 AM
You can run an obd1 P0F ecu too if you can find one cheap, not sure what country you're in. It's from an accord h22 and has the A6 and A11 pins switched so you won't have to worry about swapping them.
supercd5accord
Mar 19, 2012 01:53 PM
CarlosT
Dec 14, 2011 11:08 PM
sammcdade93
Aug 31, 2011 09:25 PM
Bacondoggy
Oct 8, 2009 08:12 PM
hitek85
Feb 12, 2008 10:32 AM
