Won't Start
Old Jun 7, 2008 | 07:02 PM
loc1979
Default Won't Start
My 2000 Accord won't start unless I push the brakes in real hard, put it in neutral then started then it will start. What's the problem? Please help. Thanks.
Old Jun 7, 2008 | 08:29 PM
nafango2's Avatar
Default RE: Won't Start
do you mean to say it wont start in park? or do you have a manual transmission?
sounds like the brake switch might be broken/misaligned. peek under the dash and take a look.
Old Jun 8, 2008 | 08:55 AM
loc1979
I have an automatic. I can't turn the engine in park but if I press the brakes in real hard, put it in neutral then it will start. Someone told me it be a neutral safety switch?
Old Jun 8, 2008 | 02:28 PM
nafango2's Avatar
if the engine doesnt crank over at all in park its most likely the neutral safety switch. I would check the brake switch alignment as well.
Old Jun 8, 2008 | 02:45 PM
loc1979
We looked at the neutral safety switch and itseems fine. And sometime when the engine is already on I can't put the car into gear. Thanks.
Old Jun 9, 2008 | 02:03 PM
KevinAccord's Avatar
fuse blew... 95% sure.... check fuse box under hood...
Tony1M
Nov 6, 2023 08:29 PM
Sheri6889
Jun 17, 2015 08:19 AM
droptail
May 17, 2005 10:37 PM
dgeorge
Nov 29, 2004 01:40 PM
