**need major help on my honda**
Old Feb 2, 2012 | 12:36 AM
AngelandAlexis Jimenez's Avatar
Exclamation **need major help on my honda**
Okay so my alternator went out and we replaced it and a week later my honda just squeels all the time when it is on. I dont know what is wrong with it and need help, please take me serious im only 18 and not educated that well yet..... Any ideas whats wrong with it?
Old Feb 2, 2012 | 07:24 AM
Welcome!
This "new member" section is just for welcome & introductions, so I'll move this over to General Tech.
What year & what engine is your Accord? From 1977 to 2012 they are not all exactly the same. Some years can operate without the alternator belt, to verify the source of the noise. Newer ones cannot because that belt drives the waterpump.
Old Feb 2, 2012 | 08:05 AM
I am going to guess the alternator belt is loose, causing the squeeling.
Old Feb 4, 2012 | 07:24 PM
Default to jim
Oka well jim i have a 91 honda accord lx, but the guy i bought it from put a 96 engine in it. Ive spoke to people at my job and they say its eother my tensioners, water pump, or pullies, or even all my belt.... Not quite a set target..... One guy said to take a long screw driver to the parts and see which one was makin the squeeling noise and it turns out to be my crankshaft if im not mistaken
Old Feb 4, 2012 | 09:01 PM
UhOh's Avatar
This is probably not a major problem
also my guess. you can keep driving it.
since you don't know cars, go to an auto parts store early in morning (not busy) and ask the guy
to come out and look/listen at it and pass judgement on cause.
it's simple to tighten belt, ask him how while he's there. if you don't have
basic tools, ask him if he'd tighten it for you for $3 (cash on the side).
EDIT: longer term you'll want to develop friendships with couple people who know cars
Old Feb 5, 2012 | 07:04 PM
Well i work with guys that do know but we havent had time to meet up and really check it out to even see what the real problem is. And i think its my crankshaft cuz i took a screwdriver and listened to certain parts that would squeel and that was the one of the few that was squeeling. So i just need a professional to take a look and ill get it fixed asap... Thanks you guys for the help ill be back if i need more help
Old Feb 5, 2012 | 07:24 PM
A crankshaft generally don't cause a squeal sound. It is more likely the power steering belt or alternator belt being loose since the alternator was replaced recently and those belts were probably removed.
Old Feb 6, 2012 | 09:14 AM
If the belts are old, don't just tighten them. Old belts get hard & slippery, and when you over-tighten them you make the bearings (alternator, PS pump, etc) wear out more quickly.
2003 & newer have a single serpentine belt with a spring-loaded tensioner. Also, 2003 & newer 4-cyl waterpumps are driven by the external serpentine belt. That's why I asked the year.
Old Feb 10, 2012 | 04:18 AM
Redbull. You do have a point but i need to get it checked out asap so i know what is really wrong with it so i can get it fixed and back to its oldself and not squeel.... And jim i understand that cuz my mom has a 2009 and i noitced the serpentine belt as well. And also the dude that sold me the car was a dumb *** for stickin the 96 engine in there in the first place cuz it makes **** harder for me to figure out whats wrong with it... And that makes it harder on me
Old Feb 10, 2012 | 06:52 AM
crispin's Avatar
I would not say that the PO was dumb for installing a newer motor in your car.
That is a very normal thing to do and I would be very happy to have a 96 motor in a 91 body.
Anyway you are making this much harder than it needs to be.
You need a 12 mm socket on the end of an extension, pull the power steering reservoir up and out of the way to make it easier to get to the lower nut.
It will take about 10 mins to do.
Michael Bomes
Jan 31, 2013 02:42 PM
nocode
Jul 23, 2012 05:53 PM
o CRA5H o
Feb 20, 2011 06:11 PM
brishaunhorne
Jan 5, 2011 07:12 PM
ahntrio3
Nov 5, 2007 06:15 PM
