[Deleted]
Old Aug 14, 2007 | 07:53 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Aug 14, 2007 | 08:32 PM
Default RE: MPG
Unless you have a really lead foot something's wrong.My 94 EX has always generated 25-27 mpg w/ about town driving and 30 mpg on the road. It has 225K miles at present.
Things to check. Tire pressures, brake caliper piston sticking causing excessive pad drag, intake air filter, thermostat (too cold engine temp lowers mpg), fuel pressure regulator (pull vacuum line and sniff for gas, if yes replace regulator), PCV valve and hose clear, throttle plate and IACV clean, base timing at 15 btdc, check engine compressions (should be 180 psi, min 135psi, max variation 29 psi, check w/ WOT).
superballz00's Avatar
Almost A Senior Member
Default RE: MPG
I get close to 30mpg with my 97 LX coupe. Thats with about 80% freeway with some morning traffic and A/C is on almost all the time.
Old Aug 14, 2007 | 09:52 PM
YeuEmMaiMai's Avatar
Default RE: MPG
my 94 accord lx got about 24-25 around town and 34 freeway. When my tstat stuck open it dropped to about 22 around town. might want to make sure that your engine is reachin proper operating temp
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
