[Deleted]
Old Apr 28, 2006 | 05:54 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Apr 28, 2006 | 07:44 PM
sir_nasty's Avatar
Default RE: Crazy car 93 accord
pull one of the spark plugs after you turn it over for a while and see if there is any fuel on it.... if there is then I would guess it's a spark issue... Does it do anything else that's funny? does it do this after the car has warmed up/been run for a while? what engine do you have?
WELCOME TO THE FORUM!!
Old Apr 28, 2006 | 08:02 PM
deserthonda's Avatar
we need to verify if it is lack of spark or fuel..
Here is what you do,, get a can of carb cleaner do not get start fluid,, that thing sucks..
anyho,, when car does not start, remove the intake tube that goes to throttle body, open the butterfly and spray some carb cleaner in throttle body, crank the engine ,if it starts it is lack of fuel
common problem on those MAIN RELAY .. could be FUEL PUMP. as well
here is some info on main relay ...
http://techauto.tripod.com/s.htm
if still does not start, pull a spark plug wire, if you have an old plug insert it into the wire , ground the plug, crank the engine and chk for spark, if you do not have an old plug you can use a screwdriver, ..make sure to ground the metal part and chk for spark, ,,if no spark
common problem IGNITOR, COIL ,ROTOR., would have to test to properly diagnose
try this and post results we will go from there
Old Apr 28, 2006 | 11:29 PM
lightshow's Avatar
i think its the main relay
Old Apr 30, 2006 | 01:40 AM
Yo Barryl ,, let us know what you find..
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
