[Deleted]
Old Apr 22, 2007 | 12:59 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Apr 22, 2007 | 01:31 PM
Shadow1992's Avatar
Default RE: 1994 Accord Motor Mounts
There are 4 mounts total..there is another one near the firewall below the intake manifold. Kinda hard to see. To do a check you need to get a dolly jack and place it under the oil pan and lightly jack up the engine so pressure is taken off the mounts. Then look at the mounts checking for tears or cracks, make sure the rubber isn't hardened or seperated from the metal. Then check to make sure the mount is securely attached to the frame, you can use a large screwdriver to pry on it to see if it moves. If it does lower the engine and tighten the mount bolts. Apply rubber perservative to the mounts to slow deterioration.
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
