[Deleted]
Old Apr 23, 2007 | 03:54 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Apr 23, 2007 | 06:02 PM
deserthonda's Avatar
Default RE: Accord Coolant Change?
any brand antifreeze will do ,,
when you replace it,, make sure to bleed the system
Old Apr 23, 2007 | 06:08 PM
With any luck, this isn't the first time it's ever been changed. If you don't know what type antifreeze is in there now, it's best to rinse a couple times so ALL the old stuff is gone. Certain combinations of old & new don't play nice together. Especially if the PO ever put DexCool in there.
Old Apr 24, 2007 | 03:02 PM
Pauls95's Avatar
i've just drained the radiator from the petcock valve & refilled it about every 2 years. takes ~30 minutes in your driveway & costs ~$10. imho, aggressively flushing your cooling system tends to stir up a lot of sediment in your cooling system that can trash your water pump.
Old Apr 24, 2007 | 03:11 PM
wietgr's Avatar
Full system flushes are really only needed if the coolant is excessivley dirty. A drain and refill is just fine.
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
