00 accord v6 coupe running rich
Old Nov 4, 2011 | 01:44 PM
Hancock0's Avatar
Default 00 accord v6 coupe running rich
I have burned up 3 cats since December. I hav changed all the o2, map and maf sensors. Plus when on a cold start the car the rpm rev to 2000 the creeps back and when i take off it boggs out until i release the gas and step back on the pedal. Also when I put the car in park the engine revs up n dwn from 1200-2000 rpms. I have a aem v2 cold air intake. any suggestions on what it could b???
Old Nov 4, 2011 | 01:53 PM
bpp's Avatar
bpp
Are you getting any CEL codes? What type of CAT are you using (I assume its not OEM)?
Old Nov 4, 2011 | 02:05 PM
Hancock0's Avatar
No error codes. And it's an aftermarket cat from the muffler shop by the house. I been going there for yrs. u can smell soooo much gas coming from the exhaust
Old Nov 4, 2011 | 02:41 PM
bpp's Avatar
bpp
Are you sure? You should probably be getting multiple codes either as misfire, o2 codes, cat code (p0420, etc.). You really should be using an OEM Cat. However, if I was diagnosing this I would be looking at live data; o2 sensors, short term fuel trim, long term fuel trim, etc. Hopefully someone with a bit more experience can chime in but I dont know how much we can figure out with codes or graphs of live data.
Old Nov 4, 2011 | 02:52 PM
Hancock0's Avatar
It's hard trying diagnose this with no codes. I have nvr had codes for my o2 or cat during this whole process. All the codes I had I fix which were unrelated to this problem.
haoleflip719
Sep 22, 2024 12:22 AM
Novaknowledgenow
Dec 1, 2014 11:29 AM
DJnickchris3
Jun 19, 2012 08:20 PM
priscilla2237
Aug 1, 2007 01:20 PM
mbo1985
14
Apr 24, 2006 09:31 PM
