01 Accord Sedan Rattling Noise
Old Jan 23, 2013 | 07:28 PM
umg1989's Avatar
Exclamation 01 Accord Sedan Rattling Noise
I have a 2001 Honda Accord LX Sedan. Just recently it started making a noise (like when your making popcorn) from the right side of the motor around the timing belt area. Its a low noise you can hear it when its at a stop. It only makes that noise when im on my way from work when the car is wamred up/hot. Before it started making this noise i got a brand new EGR Valve, Gas Cap, and Catalytic Converter & did a tune up.
Old Jan 24, 2013 | 09:44 AM
Considering the bad consequences of losing a timing belt, you should probably remove the upper timing cover & have a look around.
Bad belt beginning to make noise? Change it quick before it breaks.
Tensioner pulley bearing? Waterpump? Any of that stuff can throw your timing belt & you end up with bent valves.
I had a very loose waterpump on a VW. It didn't leak, but when I loosened the belt I could wobble the pulley. It made a rattling sound a bit like you're describing.
smilano
Jun 16, 2011 06:17 AM
Hondalover
Mar 14, 2011 03:04 PM
acc0rdman
Sep 17, 2008 08:24 AM
kidwidstyle
Mar 28, 2007 12:36 AM
Gage05
Dec 4, 2006 02:26 AM
