01 accord V6 sedan keeps draining the battery after changing alternator
Old Mar 29, 2012 | 04:20 PM
01SilverAccord's Avatar
Originally Posted by PAhonda
What brand of alternator did you install in your accord?
It's Worldwide Alternator - 105 Amps at Advance auto parts.
The battery died again and the parasitic test didn't show any amp drawing..
Old Apr 12, 2012 | 08:12 PM
Does anyone know what this part call?
it's right after power steering reservoir. I accidentally hit it and the cable was throttle cable was loosen and the car wouldn't start. I tried to push the cable back inside but I could only push it back a little like in the pic
Since then, the car idles fine but when I give it a little gas, all the rpm needle, gas needle, and temperature needle dropped like the car is shutting down.
Is the part in the pic changable? or can I open it up? I was tempted to do that but just want to ask for advice first. Thanks
Old Apr 12, 2012 | 08:39 PM
It the cruise control actuator. See attached image. The parts can be changed, etc.
Attached Thumbnails 01 accord V6 sedan keeps draining the battery after changing alternator-cruise-control-actuator.jpg
Old Apr 12, 2012 | 08:41 PM
thanks for the info.. I'll check that out..
Old Apr 15, 2012 | 09:07 PM
I check the wire from the alternator to the fuse box and it's corroded so bad to the point I don't think it has any connection.
I'm trying to replace the terminal ring but the wire itself is gone. Does anyone know if i can order it online? I don't want to go to stealership and pay $50 for that wire.
Old Apr 16, 2012 | 06:17 PM
Might check the prices online and see what the wire/cable goes for.
If not, in my day, you can look around for local places that can/will make cables. When I use to sell parts for a living, we had/sold pre-made cables but at the same time we were set up to make custom cables.
Old Apr 18, 2012 | 09:07 PM
  #17
I've checked online store and it seemed nobody carry that cable and I've been driving around, parts store told me go to the dealership. Sighhh....
Old Apr 18, 2012 | 09:46 PM
  #18
I would try to find the oem part number for that wire. There are sites like hondapartsnow.com that give oem numbers.
You may want to call the dealership to find out what they charge for one.
R0CKY
Dec 6, 2010 08:59 AM
MyBrotha92LX
Oct 2, 2009 07:12 AM
MyBrotha92LX
Oct 2, 2009 06:33 AM
driver6198
Jan 2, 2009 11:19 PM
