'02 random electrical loss
Old May 24, 2012 | 06:19 PM
Sils79's Avatar
Default '02 random electrical loss
Hi all, hopefully someone can help me with my car's issue. I have a 2002 Accord SE 4cyl with 145K. While driving, the vehicle will randomly lose electrical power for a split second. Usually the radio and air shut off, and sometimes the gauges drop. They all immediately come back on-line. The clock has reset a couple times. This electrical loss does not seem to affect the engine though and i just keep on driving. It usually happens between 25-45 mph, but sometimes happens at stops, rarely faster than 50 mph. The car has no problem starting either.
So right now it is more of an annoyance than anything else. But I don't know how long until they don't come back up. any ideas would be appreciated.
BTW, it has been several years since I replaced the battery, don't know if that matters or not.
Old May 24, 2012 | 06:32 PM
Look for a loose ground. Suggest getting a shop manual (check Online Manuals in DIY forum on this site or ebay seller automanualsource) and check underhood and underdash grounds for tightness. Any body or engine work might suggest more likely spots for investigation.
Old May 25, 2012 | 09:43 AM
Can you make it happen by wiggling the key?
Old May 26, 2012 | 03:12 PM
Sils79's Avatar
no, I can never make it happen, sometimes I will take a 1/2 hour trip and it never happens, sometimes it happens several times in one minute. Completely unpredictable.
Thanks TexasH, I'll check the grounds.
Old Aug 6, 2012 | 02:28 PM
ks3421's Avatar
Default Same problem on '91 LX 5sp
Please post back if you determine what your problem is. I am having the same problem and it has been getting worse. At $95 per hour diagnostic fee...it will not take long before troubleshooting costs more than the car is worth (212k miles 5sp LX 4dr).
KS
Old Aug 6, 2012 | 05:29 PM
Silver6gen's Avatar
it has to be a loose ground.
Old Aug 6, 2012 | 08:46 PM
.....ks3421, you say you have the same problem....^ x2....especially if the "clock" is re-setting.....
Old Aug 7, 2012 | 06:58 AM
ks3421's Avatar
Default Solved:
I drove the car yesterday and this morning without the problem happening. Previously, it would happen every minute or so when I touched an electrical component - windows, blinker, brake, etc.
In my case, I was just starting to check everything from the battery to the fuse box and I was able to twist the positive battery cable. I removed it, cleaned it, put it back and haven't had the problem since.
Sils79...I hope yours is as simple as a loose battery cable!!!
Cheers,
Keith
Old Aug 7, 2012 | 06:13 PM
I like simple fixes
dpol86
Jan 1, 2014 10:09 PM
cumminsman
Feb 13, 2008 12:09 PM
chuckdragon
Feb 12, 2008 12:45 PM
garronriec
Sep 2, 2007 03:25 PM
94Honda
Jun 10, 2007 07:53 PM
