03 Radio/Charger non operational
Old Nov 10, 2012 | 01:21 AM
Anomonon's Avatar
Default 03 Radio/Charger non operational
Newbie to the site, Hello all.
Had this 03 since Spring of this year. Had to have the fuel latch cable replaced. During the process somehow my factory radio/cd and adapter/charger port both stopped functioning.
Slight background. When I bought the car it had some aftermarket wiring done (looks as though the prev owner had an amp installed along with a poss. sub. [and professional work imo, as I've dealt with aftermarket installs in prev. cars] The amp and wiring was left in place when I purchased from a 3rd party dealer) All radio and charger functions worked before this cable latch replacement.
I've gone through to check the fuses on my own after the dealership checked it. Seems as though all is correct there. Any thoughts?
(I'm currently in talks with HondaUSA about the dealership issue, as they claim no responsibility in the matter)
Old Nov 10, 2012 | 08:14 AM
The common fuse for what is not working is the #32 7.5amp fuse. Can you verify with a volt meter/test light the fuse and also verify one side is hot (12v) when the key is on.
Old Nov 10, 2012 | 06:27 PM
Anomonon's Avatar
Fixed, thank you for the insight.
Old Nov 10, 2012 | 08:27 PM
So... was it a blown fuse?
Old Nov 26, 2012 | 08:36 AM
Anomonon's Avatar
Yes, it ended up being the no. 32 ACC fuse.
Old Nov 26, 2012 | 09:49 PM
Thank you for coming back with the answer. Too many times these go to a dead end. Coming back with the answer helps the next person who runs into the same issue....so again thanks for the update.
carid
Dec 5, 2014 03:01 AM
cd51994accord
Jan 30, 2014 12:56 PM
Derek B
Jun 22, 2011 03:36 PM
loki
Jan 13, 2008 10:06 PM
yank4life
Nov 13, 2006 09:42 AM
