04 accord ex coupe 4cyl heating problem
Old Feb 9, 2011 | 10:56 AM
trmccone's Avatar
Default 04 accord ex coupe 4cyl heating problem
I have an 04 accord ex coupe and when the car is sitting at a stand still the heat blows cool air but while driving it blows hot air. Can someone please help me fix this problem?
Old Feb 9, 2011 | 11:07 AM
stir_fry_boy's Avatar
Either you don't have enough coolant in your car or your thermostat is bad. Change with Honda parts (thermostat $20 and coolant $20). This would be a good time to do a drain and fill with Honda coolant.
Old Feb 9, 2011 | 11:12 AM
Lightbulb Hi Member
1st off let's say that stir fry boy has a good answer for you to do 1st..and let's sak You...what have you done to correct or researched your problem already.?
Old Feb 9, 2011 | 11:42 AM
trmccone's Avatar
All I have been able to do so far is search this forum for help. I have been working the night shift and my wife called me last night and told me what it was doing so I was trying to just see where would be the best place to start looking. Thanks for the help so far. Will keep you updated.
Old Feb 9, 2011 | 02:52 PM
trmccone's Avatar
I have drained and flushed the radiator and am flushing again and the heat is kicking out great now. Thanks for the help.
Old Feb 9, 2011 | 03:00 PM
Hondas (as a general rule) do NOT like to have air pockets in the cooling system. Your 2004 doesn't have a bleed-valve like earlier ones. But still, turn the heat all the way up and run awhile to allow air to collect at the radiator cap. Then open & top it off when it's cool enough to do that safely.
Your thermostat is very easy to replace, if needed. Get one from a Honda dealer cause they seem more reliable and they aren't stupid expensive. The lower radiator hose comes from the bottom of the radiator & crosses diagonally to the thermostat housing. There's a metal spring-clip that you squeeze & pop the T-stat housing open. (All the guys with F-series engines are green with envy)
hydroguy87
Jun 15, 2014 07:15 AM
deloreselizabeth93
Jul 9, 2012 04:07 PM
trballa17
May 22, 2009 08:54 AM
kidgravity
Dec 5, 2008 09:11 PM
CEJLG541
Mar 8, 2008 04:49 PM
