04 accord odometer display counting
Old Jul 11, 2014 | 10:58 PM
FotG's Avatar
Default 04 accord odometer display counting
I have an 04 Accord LX v6 nav and I was holding down the odometer button to reset the maintenance required light and I noticed the trip-odometer display started counting 0, 1 ,2 ,3 ,4 ,5, -5, -4, -3, -2, -1,0 and back again. What does this mean or what does it do?
Old Jul 11, 2014 | 11:39 PM
EXV6NIGHTHAWK's Avatar
I think you were adjusting the outside temperature reading. From the numbers you posted, I assume you can adjust it up or down by 5 degrees. To reset the maintenance required light: Key turned off, push the reset button with your left hand, continue to hold the button down and turn the key to on (no need to start engine). Hold the button down until the light goes out. Look at the little dimple in your finger, from holding the button down so long.
Old Jul 12, 2014 | 12:01 AM
Yep, outside temperature display adjustment feature.
Attached Thumbnails 04 accord odometer display counting-indicator.jpg   04 accord odometer display counting-outside-temp-indicator.jpg
Edegas
Jul 22, 2009 11:51 AM
eric123
Jan 3, 2008 07:14 AM
innominate
Oct 14, 2007 09:10 PM
ibornagain
May 12, 2007 08:51 PM
