04 accord outside temp gauge stuck at 70
Old Jun 14, 2006 | 02:56 PM
segen77
Default 04 accord outside temp gauge stuck at 70
The subject pretty much sums it up. This jsut started today. I turn on the car. It comes up with the three dash's like it's trying to get the temp, then it just sits at 70. I'm in texas, and I know it's not 70 outside. The real kicker is I'm just past the warranty. Let me know if anyone has any ideas what this could be.
Thanks
Old Jun 14, 2006 | 09:58 PM
lightshow's Avatar
Default RE: 04 accord outside temp gauge stuck at 70
dang sucks about the warranty. my first guess would be a bad temp sensor, but maybe its just a bad connection.
Old Jun 15, 2006 | 05:04 AM
deserthonda's Avatar
you can remove and test the outside air temp sensor.......it is located behing the frt bumper, in frt of the condensor., 2 wires going to it,, plug is gray in color
anyho. you need a multi meter, set it on ohms and chk the resistance ,, hook up the ohm meter to the sensor..
Put the sensor in ice water and chk resistance , at 32* should be around 6.5 ohms,
than pour some warm water and chk to make sure that there is a change in resistance ,, the warmer the less resistance
at 50* around 4 ohms
at 68* around 2.5 ohms
at 86 * around 1.5 ohms
at 104 * around 1 ohm
Old Dec 9, 2007 | 05:56 PM
david369601
The IP temp gage reads consistantyl 3 degrees higher than true in my '03 Accord. Any ideas to correct this? It's nice to know when the temp is cold enough for the roads to start freezing up.
Old Dec 9, 2007 | 06:55 PM
HondatechAV6's Avatar
Turn the ignition switch ON (II). Go to the outside air temperature display. [/ol]
Press and hold the reset select button for 10 seconds. While you continue to hold the button, the display will scroll through temperature settings from +3 ยบ to -3 ยบ. If thet actual temperature is 32F and the dash is showing 35F hold the button until -3 is shown, then release andturn the key off, then turn the car on and check. [/ol]
rimidalvr1966
Oct 28, 2013 10:35 AM
pirulino23
Nov 10, 2010 06:18 PM
zoominhuman
May 30, 2007 06:08 PM
longhornjohn
Aug 26, 2006 07:32 PM
corr04
Jun 7, 2006 01:24 AM
