04 accord Trans swap
Old Nov 30, 2009 | 08:48 AM
tha_juggalo's Avatar
Default 04 accord Trans swap
I have an 04 Accord EX 2dr V6 auto that i am wanting to swap over to 6spd.
I have access to an 04 6spd car that is a rearend total upto the back of the front seats. I am just wondering what I need off of the donor car so that i can get it all at once instead of sitting here waiting on stuff that i didn't know i needed.
This is what is being pulled now... anything i need that is not listed let me know PLEASE!
1. Motor and Trans
2. ECM
3. Shifter and and cables
4. Clutch peddle and cables
Old Nov 30, 2009 | 09:01 AM
Cluster is different without the lamps for PRNDL
Parts of the console & trim around gearshift lever??
Clutch is hydraulic - you'll need the clutch master cylinder & all the tubing runs & brackets.
This would be better in General Tech so I'll move it.
Old Nov 30, 2009 | 04:23 PM
finch13's Avatar
Cluster would be a good idea, digital odometer would be different in your car.
You need the tranny-side engine mount.
Old Nov 30, 2009 | 04:28 PM
Are the other engine mounts the same?? Any vacuum-operated mounts like in the 4-cyl cars? (those are different auto vs. manual)
Old Dec 1, 2009 | 03:13 PM
The mounts are coming with the engine, the console trim is coming with the shifter, the Master cylinder and clutch tubing runs and brackets and peddle are coming with the trans, just called and had the dash cluster pulled....
vipernj
Oct 7, 2008 11:04 AM
spaztikone
Jul 18, 2008 08:16 AM
pelon1416
Apr 12, 2007 04:00 PM
noboundaries6289
Feb 15, 2007 02:06 PM
thecaveboy
Jan 24, 2007 10:51 AM
