04 accord Trans swap
I have an 04 Accord EX 2dr V6 auto that i am wanting to swap over to 6spd.
I have access to an 04 6spd car that is a rearend total upto the back of the front seats. I am just wondering what I need off of the donor car so that i can get it all at once instead of sitting here waiting on stuff that i didn't know i needed.
This is what is being pulled now... anything i need that is not listed let me know PLEASE!
1. Motor and Trans
2. ECM
3. Shifter and and cables
4. Clutch peddle and cables
1. Motor and Trans
2. ECM
Cluster is different without the lamps for PRNDL
Parts of the console & trim around gearshift lever??
Clutch is hydraulic - you'll need the clutch master cylinder & all the tubing runs & brackets.
This would be better in General Tech so I'll move it.
The mounts are coming with the engine, the console trim is coming with the shifter, the Master cylinder and clutch tubing runs and brackets and peddle are coming with the trans, just called and had the dash cluster pulled....
noboundaries6289
Feb 15, 2007 02:06 PM
