04 Accord Wiper and Pump Not Working
Old Nov 3, 2013 | 01:49 PM
semmons23's Avatar
I can get the motor to start with power on 5 but not with power on 2 - via secondary power source. Does that mean the motor is bad?
Old Nov 3, 2013 | 05:22 PM
Originally Posted by semmons23
2 is green and has 11.76 volts
5 is white and has 10.58 volts
This is with key in pos II and switch on high or low
1 blue
2 green
3 black
4 yellow
5 white
A little unsual, if you have a sedan (4-door), the wiring you listed looks like how it would be for a coupe based on the circuit diagrams.
Looking at the electrical circuit diagrams:
Sedan (Grey connector – wire side of female terminals):
  • Terminal 1 (Blk wire) is ground (ground comes via ground connection G302 – behind left front bumper)
  • Terminal 2 (Green wire) should have power when ON or START (power comes via under-hood fuse No. 11 (30A)) – OK
  • Terminal 3 (Blu wire) Motor low input control - provides ground via the Windshield Wiper High Relay in Low Speed Setting
  • Terminal 4 (White wire) PARK/ RUN Output - should have power via the Intermittent Wiper Relay in Run, Low or High Speed Setting
  • Terminal 5 (Yellow wire) Motor high input control - provides ground via the Windshield Wiper High Relay in High Speed Setting
Coupe (Black connector – wire side of female terminals):
  • Terminal 1 (Blu wire) Motor low input control - provides ground via the Windshield Wiper High Relay in Low Speed Setting
  • Terminal 3 (Blk wire) is ground (ground comes via ground connection G302 – behind left front bumper)
  • Terminal 4 (Yellow wire) Motor high input control - provides ground via the Windshield Wiper High Relay in High Speed Setting
  • Terminal 5 (White wire) PARK/ RUN Output - should have power via the Intermittent Wiper Relay in Run, Low or High Speed Setting
Old Nov 3, 2013 | 06:01 PM
semmons23's Avatar
Sorry I was looking at the picture from the wrong side (pin side not wire side). So it should be 1,3,5 are ground
2 is 11.76 and 4 is 10.58
Sorry!
Old Nov 3, 2013 | 06:13 PM
This is part of the motor test (for sedan):
Disconnect the electrical connector.
  • On the motor side, apply battery power to terminal 2 and ground to terminal 3; the motor should run at low speed and smoothly.
  • On the motor side, apply battery power to terminal 2 and ground to terminal 5; the motor should run at high speed and smoothly.
Old Nov 3, 2013 | 06:14 PM
semmons23's Avatar
Seems that it would also mean that the motor will run with power on 4
Old Nov 3, 2013 | 06:24 PM
semmons23's Avatar
Thanks. I'll have to try this tomorrow and see what I find. Could a bad wiper motor cause the windshield cleaner pump motor any issues? Definitely a smaller concern...
Old Nov 4, 2013 | 08:07 AM
  #17
semmons23's Avatar
So I found the 7000 page honda manual and ran thru the testing process as best I could. I have power on 2 and one of the steps was to check for continuity between 3 and 5 and 2 and 4 on the wire harness so I did. 3 and 5 had continuity but 2 and 4 didn't. the manual said that if I didn't have continuity then to test the motor. Do I or don't I have continuity since one did and one didn't? I tried to get the motor to run using the above steps but it wouldn't. At this point I'm planning on getting a new motor - do you agree?
Old Nov 4, 2013 | 11:00 AM
  #18
1. The test you're referring to sounds like the test for continuity at the Blue the Yellow wires, respectively.
  • For the Blue wire, continuity is tested between the No. 2 terminal (at Relay Control Module - Connector J) to the No. 3 terminal (at the wiper motor harness connector: Grey connector – wire side of female terminals).
  • For the Yellow wire, continuity is tested between the No. 4 terminal (at Relay Control Module - Connector J) to the No. 5 terminal (at the wiper motor harness connector: Grey connector – wire side of female terminals).
2. If you could not get the motor to run with the following steps, sounds like the motor is faulty.
Old Nov 4, 2013 | 12:45 PM
  #19
semmons23's Avatar
I got a new motor and plugged it in and it worked. Now I just have to remove the old one and install it. Thanks for all your help!
Old Nov 4, 2013 | 12:48 PM
  #20
No problem. Glad to hear and thanks for reporting back.
