05 Accord Windows click but dont move
Old Jul 13, 2016 | 08:06 PM
JarvisW's Avatar
Default 05 Accord Windows click but dont move
Hi, This may be because I tried to swap PCMs from my AC problems thread, but here goes..
I tried to use the brake code for a spare PCM given by the Honda Dealer, but I'm afraid it was for the car/VIN and not the new PCM, so I put the ORIGINAL PCM back, and the car runs and drives. (no CELs)
Drivers window works, and so does its Auto, the rest have nothing.
They were working just fine until I did that, and now they just click. No sounds if I lock them at the drivers panel.
I tried the reset trick found here https://www.2carpros.com/questions/h...ws-not-working
And it does not seem to change anything. Auto still works once I go thru those steps 4x.
So, what should I look for? Did I mess something up by swapping PCMs?
Old Jul 15, 2016 | 11:06 AM
I couldn't get the link to open, probably me and not the link.
There is a re-set procedure in the owners manual. If I remember correctly it is supposed to be done whenever the battery is disconnected for a period of time.
Old Jul 15, 2016 | 10:24 PM
JarvisW's Avatar
Thanks. I did disconnect the battery.. this is the instructions that link gives, but can't seem to get it to work...
RESETTING THE POWER WINDOW
1. Turn the ignition switch ON (II).
2. Move the driver's window all the way down by using the driver's window DOWN switch.
3. Open the driver's door.
NOTE: steps 4 - 7 must be done within 5 seconds of each other.
4. Turn the ignition switch OFF.
5. Push and hold the driver's window DOWN switch.
6. Turn the ignition switch ON (II).
7. Release the driver's window DOWN switch.
8. Repeat steps 4 - 7 three more times.
9. Wait 1 second.
10. Confirm that AUTO UP and AUTO DOWN do not work. If AUTO UP and DOWN work, go back to step 1.
11. Move the driver's window all the way down by holding the driver's window DOWN switch to the AUTO DOWN position.
12. Pull up and hold the driver's window UP switch to the AUTO UP position until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window master switch is reset by using the driver's window AUTO UP and DOWN function.
If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps. If it still does not work, go to B-CAN System Diagnosis Test Mode A.
(and thanks for your service!)
Old Jul 20, 2016 | 11:21 AM
JarvisW's Avatar
Got a new PCM reprogrammed for the AC problem, but thw windows still dont work.
I'll get it back in a week or two, so I'll mess with that then.
Gotta take the door panel off anyway and change the door handle cable and check to see why it wont stay open on the half way point, only works fully open.
But I'll deal with that when the time comes.
Thanks!
2ToeRacing
Mar 2, 2014 02:26 PM
ChicagoBob123
Jul 17, 2012 12:14 PM
69sixpackbee
Nov 11, 2011 11:49 AM
elmorgilmo
Mar 9, 2011 07:31 PM
rambzy
Dec 3, 2010 11:52 AM
