05 Break noise
Old May 12, 2010 | 01:36 PM
Frosti1's Avatar
Question 05 Break noise
I have an 05 Accord with less than 60000 miles. Coming back form vacation I started to hear a knocking sound when I applied the breaks. If I have to push the breaks hard the noise is real loud. You can't feal anything in the pedal. Any thoughts??
Old May 12, 2010 | 04:18 PM
This belongs in General Tech so I'll move it.
Old May 12, 2010 | 06:14 PM
deserthonda's Avatar
make sure wheel lug nuts are tight , if so...,remove the wheels and inspect brakes, calipers, frt suspension components for wear or loose bolts,,
Old Jun 1, 2010 | 06:33 AM
Frosti1's Avatar
It sounds like it is coming from the rear. Could this be part of the ABS system?
Old Jun 2, 2010 | 11:17 PM
could be a # of things , it is almost impossible to properly diagnose noises without being there to hear it ..
chk rotors for warpage , besides all the stuff i advised before ,, if it is coming from the rear , chk all the rear components ,,
Old Jun 4, 2010 | 12:26 AM
kris_loehr's Avatar
I would check how much pad material you have left on the rears. On some of the newer Accords like my 2003 the rear pads don’t last long.
thunder_x
May 7, 2007 05:27 AM
scottymac
Aug 30, 2006 03:58 PM
blackpearlv6
Jun 13, 2006 10:19 AM
bigheadballer
Aug 27, 2005 08:16 PM
bigheadballer
