Sponsored by:
Sponsored by:
05 V6 4 door weird ac issue
Old 07-13-2017, 01:43 PM
dirtbikedad's Avatar
Default 05 V6 4 door weird ac issue
When I turn on the ac it blows cold air on passenger side vents, and warm on drivers side vents. Even the vent in the center of the dash is split cold on passenger side and warm on drivers side.
Eventually it seems to start working ok but can do this for some time. In the Alabama heat and humidity I need it to work all the time.
Any ideas?
Old 07-13-2017, 01:54 PM
The Toecutter's Avatar
You might try shutting it off and re-starting it. That's what I have to do with my 06 Chevy pickup.
Old 07-13-2017, 08:55 PM
You may want to have the pressures tested on the a/c system using a manifold. The high and low side pressures can indicate the type of problem you have with the system.
Old 07-17-2017, 05:44 PM
CHUCKW's Avatar
try this video.
or this one.
Rob2000AccordLX
05-09-2014 06:23 PM
bobkat2105
05-24-2011 02:28 AM
fluxskateco
10-25-2010 06:30 AM
Esimp64
10-01-2009 03:13 PM
mig25
05-24-2007 03:50 PM
Quick Reply: 05 V6 4 door weird ac issue
