06 Accord ABS light
Old Jul 13, 2009 | 08:14 PM
johnb06accord's Avatar
Default 06 Accord ABS light
My only complaint about the car is the brakes. I replaced the front rotors/pads and rear drums/shoes due to a severe pulsation. The car still pulsates slighty after a few months. So be it. Now the ABS light popped on and stays on. Every once in a while when coming to a stop on dry pavement, the ABS acts as if I am on ice, as I can hear the system working and can feel the brake pedal rapidly pulsating. The car is a 4 cyl. auto with 52k miles. I am debating simply unplugging the ABS plug from the master cylinder. The light will still stay on and I will lose the ABS I assume, but at least I won't get the ABS acting up, as my stopping distances increase significantly when it kicks in on dry pavement. I am guessing a new ABS module or whatever you call it would be very expensive. Any advice from you Honda gurus would be appreciated. Thank you.
Old Jul 14, 2009 | 06:53 AM
I'm not aware of an "ABS plug" in the master cylinder. What is that exactly? The only plug I know in the MC is the fluid level switch.
The pulsation might be caused by not properly bedding-in the brake pads when they were new. How did you do that?
Old Jul 14, 2009 | 07:10 AM
Default 06 ABS light
Yes you're right. I think I am getting a bit senile in my old age. The plug I am talking about is on the other side of the engine compartment actually, right on the ABS contraption. I have learned to live with the slight brake pulse. My main concern is the ABS issue. Thanks.
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
swchan00
Jun 23, 2006 03:17 PM
