06 v6 3.0 LX Oil pan replacement help
Old Oct 14, 2009 | 08:44 PM
greg9442's Avatar
Default 06 v6 3.0 LX Oil pan replacement help
Ok. had to change my oil pan due to a stripped plug. The plug got worse and worse over time and eventually gave out. (Luckily while I was changing the oil) I have heard that it is recommended to replace the washer everytime you change the oil and I suppose that was my issue.
So I am now in the process of installing the new pan and wondered if anyone could give me advice on the gasket. The dealer sold me gasket in a can and I've never used it before. How tight should I crank the pan bolts? Does anyone know the torque specs?
Thanks for any input.
Old Oct 19, 2009 | 08:41 AM
Starting about 1998 the oil pan uses sealant instead of an actual gasket. My shop manual doesn't cover the V-6, so I don't know the bolt torques.
Re-using the drain-plug washer probably wasn't the whole problem. More likely it's from over-tightening it.
MikeT
Mar 5, 2015 07:12 PM
shea
Apr 9, 2010 03:12 PM
greg9442
Oct 15, 2009 10:37 AM
tjl695
May 14, 2009 03:05 PM
mcrisost1999
Jul 10, 2005 07:13 PM
