16 accord touring
Old Nov 11, 2023 | 08:37 AM
RA021826's Avatar
Default 16 accord touring
I have had a code of misfire on 4,5,6 and random cylinder misfire code replaced coil packs spark plugs timing good compression good two induction services pcv egr valves good and cleared has anyone seen this issue the light comes on and off about every ten startups after idling to temp have refurbished or remanufactured cats on one and two and new o2 sensors down shifts hard only throws the misfire codes in the system but throws every other light on battery and alternator good aswell
Old Nov 11, 2023 | 06:06 PM
Misfires on only cylinders 4,5,and 6 means something is wrong on bank 2 which faces the front bumper of your car. Since you read codes, does your code reader also read live data? Does the car downshift hard or have performance issues when the check engine light is off?
Old Nov 12, 2023 | 06:59 AM
RA021826's Avatar
yes it downshifts hard and I do but it’s to long to send in here and does have power loss
Old Nov 12, 2023 | 03:41 PM
I'd read the long and short term fuel trims on bank 1 (cyl 1,2,3) and bank 2 (cyl 4,5,6) when the engine is at operating temperature. Post the fuel trims at idle and at ~2000 rpm. Fuel trims jump around a bit, so post approximate values. You'll have 8 numbers to post on here. This will tell you how lean/rich each half of the engine is running.
Brian sabado
Aug 13, 2023 06:52 PM
joshdevries
Feb 23, 2019 03:14 PM
gary85_
May 7, 2014 05:07 PM
jbraly
Mar 28, 2013 12:41 PM
scomstock55
Dec 17, 2011 04:43 AM
