Honda accord from 1988 idle problem
Old Nov 13, 2023 | 12:00 PM
zuddxxn's Avatar
Default Honda accord from 1988 idle problem
Hello, i got an honda accord from 1988 with a fuel injected a20a3 engine and its got a idle problem from time to time, sometimes when i start it, it works fine but when ive driven it for like 10 minutes and i go to turn it off and then turn it on again it dosnt want to idle
Old Nov 13, 2023 | 12:56 PM
Does you PGM-FI warning light (or check engine light) on your dash turn on?
Your car has an ECU under the driver's seat where you can check codes. The ECU will have a window where you can see a light flashing codes. You just have to turn the key to the II position and count the number of flashes to read the code(s). Try reading the codes and post back on here.
Also, was any work done on the car before you noticed this issue?
Old Nov 13, 2023 | 12:59 PM
zuddxxn's Avatar
Yes the check engine light turn on whenever it donsnt want to idle. I dont know if my car has that window since its very old, but ill check.
hmr
Jun 27, 2019 08:38 AM
ocean0nfire
Nov 16, 2010 12:51 PM
ledlaptop
Oct 23, 2009 06:15 PM
Pat88
Jul 15, 2007 03:49 PM
jslutzky
Nov 10, 2005 12:19 AM
