1989 Accord LXi side marker light replacement
Old Sep 19, 2012 | 09:29 AM
Sundevil81's Avatar
Default 1989 Accord LXi side marker light replacement
Hello, how do you replace the side marker lights on a '89 Accord LXi? Do the lenses come off? Thanks again
Old Sep 19, 2012 | 05:49 PM
I'm going to assume the ones you are talking about are just outside of the headlight - not in the bumper.
Open the headlights - switch on the dash just to the right of the steering wheel. You can skip these next steps, I use them others do not. Pop the hood. Remove the black plastic trim around the headlight - four (?) screws, two above the headlight and one on each side of the headlight.
From there, there is two screws holding the outer lights, should see two holes giong front to rear - you removed the trim around the headlight to get good access to these holes. Stick your phillips screw driver into each of those and remove the two screws.
Once those screws are out - pull the light straight forward.....there are two plastic pins on the back of the light that you do not want to break....
I can take pics if this doesn't help.
EDIT: found this in the manual....I can still take pics of one of mine if needed.
Attached Thumbnails 1989 Accord LXi side marker light replacement-3rd-gen-frt-sidemarker-light.jpg
Old Sep 20, 2012 | 07:01 AM
Sundevil81's Avatar
Default 89 Accord LXi
I located the screws for the side marker lights...Had to pop the healights up and found them...things are well hidden.
Old Sep 20, 2012 | 08:09 PM
Yea, just wait until you have to replace the bulb in the turn signal in the bumper
As I said, I remove the trim around the headlight just for ease of getting to those two screws and being able to pull the lens straight forward.
Thanks for the follow up
Did I ever say that I like the 3rd gens.......
jordanKT19
Aug 31, 2014 11:11 AM
Pajamarama
Jun 8, 2012 08:57 AM
pmurph13
May 3, 2011 10:28 PM
boredguy
May 2, 2011 01:09 PM
Dante
Jan 30, 2010 11:50 PM
