1989 honda accord lxi manual
Old Dec 20, 2012 | 06:02 PM
lindsey453's Avatar
Default 1989 honda accord lxi manual
so i have an 89 honda accord lxi. the car will turn over but won't start, the fuel pump wont come on. and i have no power at #2 or #7 in the main relay wiring, and i also have no power at the efi ecu starting signal spot in the fusebox under the dash?
Old Dec 20, 2012 | 06:57 PM
Our numbers may be off....I see #2 as a ground?
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
Old Dec 20, 2012 | 07:10 PM
lindsey453's Avatar
i replaced the main relay with a brand new one. and the check engine light doesnt come on. and i still have no power at the efi ecu fuse spot
Old Dec 21, 2012 | 07:16 PM
In the link I posted....use that to verify the inputs to the realy.
I'm not understanding the "no power at the efi ecu fuse spot"?
Does the clock keep time?
Does the led on the ECU - the ECU is under the drivers seat...you view the led from behind the drivers seat - flash any codes when the key is turned to on/pos II?
Old Dec 22, 2012 | 12:31 PM
lindsey453's Avatar
so on the fuse box under the dash. there is a efi ecu/starter signal spot and i have no power running through the fuse; so like when i put the test light on the fuse. the light doesnt come on.
also the 2 spots i dont have power to in the main relay is the ground spot and the other spot was the one for the fuel pump.
Old Dec 22, 2012 | 08:33 PM
On the fuse under the dash. With the key on "both sides" of the fuse have no power?
What is the back ground here? Meaning the story of how you got to this point.....just driving along and everything is working fine and the car dies.....
Old Dec 23, 2012 | 08:07 PM
lindsey453's Avatar
correct.
and the background is that i blew the car up and swapped a new motor into it. and i had it running before i left for school. but then my mom was moving it when i was gone and all the sudden it wouldnt start..
Old Dec 24, 2012 | 08:43 AM
Jump the wires to the relay......verify if voltage is going to the pump by checking at the pump with a test light or volt meter.
Double check all of the fuses under the hood.
Attached Thumbnails 1989 honda accord lxi manual-3rd-gen-fuel-relay-jump.jpg
Old Dec 26, 2012 | 01:21 PM
lindsey453's Avatar
all the fuses under the hood are good. and my check engine light doesnt come on. and i have no blinking light on the ecu but the car will still start up on starter fluid and will attempt to run.
Old Dec 26, 2012 | 01:34 PM
lindsey453's Avatar
could it be a the ignition?
