1990 accord ex won't start
Old Apr 27, 2008 | 09:14 PM
Default RE: 1990 accord ex won't start
If the light was flashing when you were starting the car when briding the yel/blk and wht/blu, then the ignitor is working properly. As for the yel/grn wire, there should be 10V when the key switch is on by measuring with a volt meter. If there is 10V and the test light isn't on between the yel/grn wire and ground, then that test will not sire. I was trying to give you simple tests to do based off of how I understand the ignitor system.
Having the test light flashing indicates that the ECU is changing the voltage for the ignitor and the ignitor is grounding the coil properly.
I would replace the coil.
Old Apr 28, 2008 | 12:32 AM
1990honda's Avatar
thanks for your quick response. connected voltmeter between yel/grn wire from igniter and chassis ground and measured 10v.
i will replace the coil and update with out come.
Old May 3, 2008 | 03:50 PM
1990honda's Avatar
i finally received the coil from mail. installed the coil, turned the ignition on without cranking the car just to let fuel flow through the fuel rail (waited few minutes), finally crank the car and it started.
thank you very much for your help PAhonda........this site ROCKS!
Old May 7, 2009 | 08:15 PM
renante
hi im renante, i have a problem also related on this problem about the car woudnt start.i have honda accord ex 90 the problem is sometimes it won't start especially if the weather is hot,but sometimes if i booster sometime it will start but sometimes it won't start..pls help what im gonna do for this problem..thanks... just email me at renantehenardino@yahoo.com
Old May 7, 2009 | 08:23 PM
renante
Default my car honda accord sometime it won't start
pls help me about my problem?i have honda accord ex 90 sometimes it wont start especially if the weather is hot..i use booster sometimes it will start but sometime it wont..how do i troubleshoot this problem?pls help just email me at renantehenardino@yahoo.com thanks a lot...
Old May 7, 2009 | 11:49 PM
renante. search the forums for main fuel relay. Sounds like the problem that you are having.
LordDCLXVI
Aug 1, 2011 07:04 AM
ejcr032
Mar 15, 2011 04:35 PM
jmalek
Mar 25, 2010 02:53 PM
chingwms06
Aug 30, 2009 07:26 AM
PedroG
Aug 6, 2006 03:25 PM
