1990 Accord exi stalling when coming to stop
hi, my 1st post. ive searched the site and have founhd some great information on stalling however not anything to do with my exact problem.
the car will start, run fine at revs then when you pull up at an intersection it will stall , everytime. things i have already replaced include..
fuel pump, ecu, low idle valve, ignition switch , throttle body and sensor, coil in distributer, exaust 02 sensor. also changed plugs/leads and reset timing.
thanks for any help in advance
Dave
(Australia)
Dave
(Australia)
This is pretty weird. Try putting the car in neutral and try the brake pedal to stop the car. Also try putting it into neutral and use the e-brake.
You can also try checking for error codes. Look at DIY section for how to check cel codes.
When started, will engine idle steadily at 700-800 rpm warm or 1000-1500 rpm cold?
If yes, then something may be happening w/ the transmission to stall the engine. The lock-up torque converter can refuse to disengage, causing the engine to stall. Very similar to a manual shift car coming to a stop w/o engaging clutch.
Suggest shorting the service check connector, and reading the D4 or S light flashes for codes. Some trans codes don't automatically set D4 or S flashing.
have now test driven car and stopped with foot brake and then emergency brake whilst car is in neutral. no change
removed exaust manifold shroud to check for another sensor. no extra sensors
re checked ecu and tcu for error codes on instrument display
ecu check - engine light comes on and remains on when blue connector is bridged
tcu check- no lights come on on D4 display.
jose310
Jan 6, 2009 05:02 PM
madsteez
Oct 26, 2008 06:02 PM
xaznxeclipsex
Sep 28, 2007 02:05 PM
badxdawgx818
Sep 4, 2007 03:36 PM
