1990 Honda Accord DX fuel gauge problem
Old Jul 15, 2012 | 06:56 PM
letsclique's Avatar
Default 1990 Honda Accord DX fuel gauge problem
Okay, My fuel gauge used to act weird. If I put say 35 dollars in gas, it would move up to near the Full line. The low fuel light use to come on when the needle was maybe 2 millimeters from the Empty line. Then the low fuel light started to come on when the needle looked like it was about a quarter of a tank full. Now the needle seems to be stuck and/or barely moving up and down maybe a couple millimeters above the half a tank line. I read from this mechanic online that usually the Accord fuel sending units are not that common a part to fail on Honda's. I am thinking about taking it to this shop I pay to diagnose problems for me, but wish I could just replace the gas gauge with one from salvage so I wouldn't have to pay a shop to diagnose whether it's the gas gauge or the fuel sending unit. Isn't it hard to replace the gas gauge? Has anyone had this problem.
_____________________________________
1990 Honda Accord DX, 2.2 L, Manual
Old Jul 15, 2012 | 07:58 PM
There is an access cover in the trunk of your car near the back seat.
I would remove that access plate to check the electrical connector. There is also a ground nearby (either under that plate, or near the plate on the outside) that you should unbolt, clean with a wire brush or some sandpaper, then rebolt.
It is worth a shot.
Old Jul 16, 2012 | 08:23 AM
letsclique's Avatar
It is worth a shot.
Awesome! Thanks for letting me know this PAhonda. Oh yeah, when I check the electrical connector, am I checking to see that it isn't loose?
I will give it a shot. I'll let you know what happens after I try.
Old Jul 16, 2012 | 06:15 PM
Yes check how loose it is also if and dirt is in there.
To add, the fuel level sender is on the right pass side.
cd_slc
Jan 1, 2013 01:03 AM
freshjiv
Oct 4, 2012 06:42 PM
nismo_guy87
Mar 27, 2011 08:36 AM
pirulino23
Nov 10, 2010 06:18 PM
woody
Sep 15, 2010 09:20 AM
