1990 Honda accord LX no 1st or 2nd gear
Old Sep 10, 2021 | 12:58 PM
Mosin_boi's Avatar
Default 1990 Honda accord LX no 1st or 2nd gear
My 1990 accord started having issues going into 2nd gear, then stopped going into it altogether (still works manually, just not in drive). Then after changing the lower shift solinoid and fluid it lost 1st gear entirely, not even manually. Then i put a new tcu into it when it was only sending 3v and that didn't fix it either. I also ran new wires from the tcu to the solinoid. The only other possible issue I could see is that my transmission dosent like the dexron IV i put in it.
What is going on with my car
the sport mode light is flashing. And the tcu is giving me codes 7 and 8
I'm only reading 3-4v at the solinoid at idle
Old Sep 12, 2021 | 09:35 PM
I don't have the wiring diagram on me, but look to see how the tcu is wired to the solenoid in a factory shop manual. There are some free versions on the web that can help.
Was any work done on your car before you noticed shifting problems?
Old Sep 13, 2021 | 01:44 AM
Mosin_boi's Avatar
I actually figured out my issue this morning, my connector from the wiring harness to the solinoid was corroded in such a way that continuity still was there but had tons of resistance not allowing either solinoid to function.
smabuki
Mar 12, 2014 12:35 AM
SanDiegoAccord90
Jan 17, 2014 12:26 AM
Ambaire
Aug 31, 2012 06:51 PM
Ice D
Jun 30, 2011 08:48 PM
Jakehansen
Jun 4, 2007 07:16 PM
