1990 Honda Accord won’t start – sometimes.
Old Oct 31, 2008 | 12:01 PM
JimY
Default 1990 Honda Accord won’t start – sometimes.
Very weird problem. 1990 Honda Accord won’t start, most of the time. At times (when it won’t start) the front flashers go off – almost as if alarm system is locking down the ignition. Had an alarm system installed a long time ago which hasn’t worked for some time?
Power is fine, Battery is strong and changed out alternator, plugs and wire cables approx 6 mths ago. Starter is fine since the car does start at times. No turnover at all when car won’t start.
Any idea’s – apprears to be electrical but no idea where to start.
Old Oct 31, 2008 | 03:50 PM
Default RE: 1990 Honda Accord won’t start – sometimes.
Check that keyswitch power to the starter solenoid (Blk/Wht) wire is energized by keyswitch turned to Start position, and check that voltage also appears at the starter solenoid. It could be bad keyswitch or an interruption from relic alarm system.
Your alarm mayonly interupt the ignition spark system, starter system, or both.
I would remove the alarm system completely. This may require a wire splice to restore.
Old Oct 31, 2008 | 04:47 PM
finch13's Avatar
Factory Honda alarma have their own harness and easily to remove, just remove the harness and plug in the original connectors. Aftermarkets alarms usually have you cut the power wire from the ignition switch to the starter, somewhere near the steering column, so the wires can pass through the immobilizer relay at the alarms main circuit board. That relay could possibly be going bad and getting frozen in an open position, not allowing any current to go through.
nufftalon
Sep 23, 2014 01:21 AM
wr400F
Dec 3, 2012 07:10 PM
evansd12006
Oct 9, 2011 09:12 PM
bboy702
Dec 29, 2009 06:42 PM
cuatro201821
Apr 1, 2008 09:06 AM
