1991 accord distributor r&r
Old Nov 25, 2008 | 05:28 PM
doubled's Avatar
Default 1991 accord distributor r&r
HYey guys, I have my new distributer , and would like to know which cylinder is #1. And also , do you have any tips for this.
Thanks
Old Nov 25, 2008 | 06:34 PM
Default RE: 1991 accord distributor r&r
Cylinder No. 1 is on the end opposite the distributor. They are numbered sequentially 1-4 from driver's side to pax side.
The distributor key fits the camshaft only one way, however it is not hard to make a mistake as the width difference of the keyway is very small. If there is any resistance to installing the key into the camshaft keyway, rotate 180 deg. and try again.
Replace the oring on the end of the distributor drive. Your new distributor should have a new oring.
CB7-SE-1991
Jan 29, 2013 04:45 PM
chingalong
May 26, 2011 11:14 PM
f18atc
Sep 24, 2009 11:50 PM
skyharborcowboy
Sep 11, 2007 10:41 PM
coolbrze
Aug 29, 2006 04:23 PM
