Honda accord distributor ?
Old Aug 3, 2006 | 12:08 PM
coolbrze's Avatar
Default Honda accord distributor ?
1st post here, seems like a pretty good site...
I've got a '94 Accord LX 2.2L all stock. I need to replace the distributor, cap, & rotor. Is it just as simple as swapping them out or do I have to adjust/set the timing? Any tips/suggestions welcome. Thanks in advance!
Old Aug 3, 2006 | 12:22 PM
deserthonda's Avatar
Default RE: Honda accord distributor ?
WELCOME to our forum........
why do you need to replace the distr ?? internal problem ? noisy ?
if you are just removing it, to replace cap and rotor, assuming the timing is ok,, get a magic marker and mark it wher it is at, that way yoiu do not have to reset timing
if you do need to replace the distr than you got to reset timing ..
Old Aug 3, 2006 | 02:53 PM
coolbrze's Avatar
The check engine light and maint. req'd lights came on so I took it to the shop. They ran diagnostics on it and told me these things needed to be done along w/ a few other things for a grand total of just over 7 bills - yeah right! Also, recently it's been a little harder to start, it cranks but doesn't catch for 3-5 sec., not like firing up right away like it used to.
How do I set the timing on this thing since I have to do dist. also? Thanks again.
Old Aug 3, 2006 | 08:01 PM
lightshow's Avatar
i woul bet that your distributor is just fine. just try the cap rotor wires and plugs first. your car will run a hellva lot better
Old Aug 3, 2006 | 08:32 PM
sir_nasty's Avatar
if you can post the codes they got from the CEL and what they said needed fixed we'll give you some responses to save yourself some serious cash AND fix the issue
Old Aug 3, 2006 | 09:12 PM
ORIGINAL: coolbrze
hook up a timing lite, the marking is on ther lower timing belt cover, line up the mark on cover with the red mark on the crank pulley ,, assuming you got the timing lite set at zero.. the white mark is top dead center . the red mark is the advanced mark, also there are 2 other marks on either side of the red mark thiose are 2 degree advance or 2 degree retarded
Old Aug 4, 2006 | 02:16 AM
Are you going to do the wires and spark plugs also..
Welcome to the forums , by the way
ORIGINAL: coolbrze
Old Aug 4, 2006 | 06:31 PM
coolbrze's Avatar
Yeah doing the plugs and wires also. OK, what I'll do is plugs, wires, cap, & rotor and skip the dist. for now. I don't need to set timing or anything like that if I don't repl. the dist. do I? Thanks again everyone.
coolbrze's Avatar
BTW - the car has 210K miles on it
Old Aug 4, 2006 | 07:57 PM
lightshow's Avatar
you dont need to set the timing to do those things. my car has 260k miles on it
