Honda accord distributor ?
Old Aug 27, 2006 | 06:07 PM
  #31
coolbrze's Avatar
Default RE: Honda accord distributor ?
ORIGINAL: deserthonda
to clear the code,, remove the back up fuse 7.5 amps from underhood fuse box for about 20 seconds,
to clear the maint lite there should be a little hole in the instr cluster, ,, stick the key in it and push it in,, it will turn from red to green
Awesome, thx! I'll let you know what happens.
Old Aug 28, 2006 | 06:52 PM
  #32
skipnstones's Avatar
OK. I am having the same problem. Checked the CEL and got nine flashes. First, I tried to clear the code but the CEL light came right back on. Went to my haynes manual and it said to look for an 8 pin connector attached to the distributor and check resistance. I cannot see any 8 pin connector. Could someone point me to a place or send me a picture of the connector. I have a 1996 LX.
Many thanks in advance.
Old Aug 29, 2006 | 02:14 PM
  #33
#5 is the distributor body, over on the right side within #5's outline is the plug...
Old Aug 29, 2006 | 04:23 PM
  #34
Thanks. I can't believe I couldn't see that.
donjuanlucas01
Feb 17, 2013 09:10 PM
skates21
Mar 18, 2012 10:22 AM
chingalong
May 26, 2011 11:14 PM
churritos567
Oct 14, 2010 08:36 PM
joelanier
Mar 11, 2008 08:06 AM
