1991 Accord EX-R Lightbulb Problem.
Old Feb 2, 2006 | 10:44 PM
s_mackenzie10's Avatar
Default 1991 Accord EX-R Lightbulb Problem.
First off, I would like to say how embarassed I am for asking this, but it has sadly come to this point. To replace a headlight bulb in an Accord, I am used to simply turning the bulb either way to unlock it and then simply pull it out. HOWEVER, due to the lack of space between the bulb and the battery and the fact that it won't turn to unlock, I have been unable to get it out!
I need someone with know-how of a 1991 Accord EXR to tell me what is going on!
Thanks,
Sean
Old Feb 3, 2006 | 12:16 AM
98accrd's Avatar
Default RE: 1991 Accord EX-R Lightbulb Problem.
You have to unplug the wire connector before you can turn the bulb to remove it.
Old Feb 4, 2006 | 07:23 AM
brownstreak's Avatar
its a pain. there is a cover that you twist!!! not the bulb!!! it all looks alike but try just grabbing the cover then twisting it. once you twist it the bulb should pull straight out.
Old Feb 4, 2006 | 08:43 PM
deserthonda's Avatar
sometimes it is really hard to twist those headlite bulb retainers,, get a screwdriver and lightly hit the bottom of ther cover going counter-clockwise,, it has happened to me before a few times , just tap the screwdriver with the palm of your hand
CB7-SE-1991
Jan 29, 2013 04:45 PM
tcmw
Nov 19, 2012 08:19 AM
kellysa111
May 8, 2009 11:43 AM
scasper
Oct 5, 2008 10:10 PM
tedog1985
Jan 5, 2006 06:43 PM
