1991 Accord LX - Fuel Pump Doesn't Prime Sometimes
Old Mar 8, 2020 | 03:06 PM
imageoftheson's Avatar
Default 1991 Accord LX - Fuel Pump Doesn't Prime Sometimes
Fuel pump has been failing to prime intermittently, as if the fuel pump is dead. After a while, sometimes 10 minutes, sometimes a few hours, pump will prime like normal and the car will start. Once started, the car has no issues.
Replaced the fuel pump, same issue. Going to replace the pump relay next.
what ​​​​​else should I be checking? Fuses, anti-theft system, ignition switch?
1991 Accord Wagon (CB9)
Old Mar 8, 2020 | 04:26 PM
The main fuel relay is the next place I'd look. That is also the fuel pump relay.
Here is a good video on repairing the main fuel relay. If you are good at soldering, this could fix your problem.
Old Mar 9, 2020 | 12:05 AM
Thanks for your suggestion and the video link. I pulled the relay and saw two of the solder points with cracks. Already ordered a new relay for $17, so we'll see if that fixes my issue.
Old Mar 9, 2020 | 12:11 AM
Old Apr 22, 2020 | 10:55 PM
Overdue update. This was the fix I needed! I just purchased a fuel relay for $25 or so, and I've had no issues since.
Old Apr 23, 2020 | 12:40 PM
Glad to hear you fixed the issue. Thanks for posting the resolution. It will help others if they are in the same situation.
josh22x
May 29, 2020 06:04 AM
RobertC
Jan 11, 2016 06:36 AM
Jmoney
Aug 4, 2009 06:38 AM
serob1977
Oct 9, 2008 08:44 AM
