1991 accord will not start
Old Jun 1, 2011 | 09:34 PM
usafshelley's Avatar
Default 1991 accord will not start
i have a 1991 honda accord that i bought from a friend, it had been sitting in his yard for about a year so i did the regular maintanence things such as changed oil and filter, fuel filter, air filter, changed power steering belt, spark plugs and wires, rotor button also found out that the transmission control module was bad and i have one on order but havent recieved yet but today i wanted to take it down the road anyways for the first time and i got about 2 miles when i started down a hill and i let off the gas and noticed that the rpms dropped and cut off. tried to restart while in neutral and still moving and it would not start, so i pulled to the side of the road and repeatly tried to start so i checked the end of the fuel rail(its getting fuel), check all spark plug wires to make sure "spark" was leaving the rotor button(got spark). So the only other thing i can think of is that the car may have jumped timing. I know the post is long but im just trying to think of all the details so i get proper feed back....Thanks!
Old Jun 1, 2011 | 10:46 PM
deserthonda's Avatar
did you drain the gas tank and install new fuel ??? I know you said that you are getting fuel but you need to chk the fuel pressure
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Brandon Hicks
May 9, 2013 06:45 PM
CB7-SE-1991
Jan 29, 2013 04:45 PM
gasface11
Jul 11, 2012 12:33 PM
