1991 honda accord bypass inlet hose
Old Mar 8, 2016 | 06:22 PM
HndaOwner's Avatar
Question 1991 honda accord bypass inlet hose
1991 Honda Accord EX-R
2.2-litre four-cylinder
I had a leaking Bypass Inlet Hose (or Heater Bypass Hose) and bought one online. When I put it on I found the hose kinked. I wasn't comfortable about the kink so I assumed I was sent the wrong hose and returned it. But the same thing happens with the second hose. So I returned it and ordered a hose directly from Honda.
When the hose came I again have exactly the same problem.
Those should be a 5/8" hose and 14" long.. all of the hoses were exactly that size.
The original hose had no kinks.
My question, is the kink going to cause a problem? Or, what I was thinking, since all the hoses I ordered, kink, can I just buy a length of 5/8" heater hose and use it. I think a piece about 16 - 17" would be enough not to kink.
I included a picture of the hose to show where the kink is.
Attached Thumbnails 1991 honda accord bypass inlet hose-heater-bypass-hose.jpg
Old Mar 8, 2016 | 09:32 PM
BlackLX4's Avatar
Perhaps the one you took out wasn't actually the "original," but rather the PO's cheap repair job that was less than quality? Just an idea.
Old Mar 9, 2016 | 06:36 AM
HndaOwner's Avatar
It can only be the wrong hose if factory built it using the wrong hose. I am the original owner and none of the hoses needed to be changed until now.
Old Mar 9, 2016 | 12:12 PM
Dr. Drivability's Avatar
Can you cut it to relieve the kink? One end or the other?
Old Mar 9, 2016 | 12:37 PM
HndaOwner's Avatar
I thought about that, but wouldn't that make the kink tighter?
I do have another hose that will go on, but it's 18" long (4" longer then the hose is suppose to be) that didn't kink when I tried it. But I don't know if I can use it or not, because it's longer. I can find nothing that says I can or can't use it.
Old Mar 9, 2016 | 12:45 PM
Any coolant hose you can make work WILL work, it's not a flux capacitor you're trying to fix.
Old Mar 10, 2016 | 02:01 AM
HndaOwner's Avatar
I don't see what the difference would be, but everything I read and found online, says it should not be more then 14"... I am going to put a longer length on and as long as there is no kinks, I think it'll be okay..
Old Nov 2, 2024 | 01:17 AM
kris_loehr's Avatar
I know this a very old post but I accidentally opened it. The thread starter needed a heater hose but kept ordering a hose to bypass the heater core and couldn't figure out the bend. Too strange
lswpubrw
Oct 8, 2011 07:47 AM
msampson77
Aug 18, 2011 04:55 PM
meggimann2000exl
Aug 17, 2011 10:53 AM
capthoward
Jul 13, 2011 04:34 PM
Larry.Strapp
Oct 24, 2010 04:44 PM
