1991 Honda Accord Electrical Problem
Hey Forum,
I hope y'all can help me out in diagnosing this problem. This started last night, I started my car, everything seemed fine, but I noticed that my windows didn't roll down, the automatic seat belts weren't moving, and I was not able to shift to any position and it was stuck on park. I had to use the shift lock key mechanism to shift. I have no clue what it can be. I hope I described the problem well enough to help me figure it out. Thanks for reading!
-Ren
-Ren
You likely blew a fuse, so check your fuses. Fuses do not just burn out over time, there is a component in that circuit that is drawing too much power.
To narrow down what is causing the fuse to blow is to turn on each component in that circuit to see what is drawing too much power and burning the fuse.
cliff
Apr 15, 2013 02:27 PM
