Sponsored by:
Sponsored by:
1991 Honda Accord LX "s" light issue.
Old 05-30-2006, 08:17 PM
lightshow's Avatar
Default RE: 1991 Honda Accord LX "s" light issue.
no prob. please let us know the solution when you find it.
Old 05-30-2006, 08:19 PM
bgs_daddy's Avatar
i hope to be able to find/fix the problem, it will be such a relief!
Old 05-30-2006, 08:24 PM
YeuEmMaiMai's Avatar
If the "s" light is lit constantly, usually indicates a problem with the TCU. if it blinks, pull the code and post it here.
Old 05-30-2006, 11:00 PM
deserthonda's Avatar
I do not think it is an issue with the VSS ,,
Also as mentioned ,, i would not condemn anything till properly diagnosing the system,,, we do not even know if there is anything wrong or it is just the different TCM causing the S lite to stay on,,
there could be more than 1 reason why s lite stays on,,
short in red wire between TCM and S switch
a bad S switch itself
bad shift position indicator
a short to power on green wire between TCM and the gauge
and last but not least a faulty TCM....
like i said earlier, if you are concerned about the S lite staying on,, First thing i would do is install the PROPER TCM the vehicle calls for ..than if lite is still on let me know we can trouble shoot the S lite stays on all the time , system
Old 05-31-2006, 01:31 AM
bgs_daddy's Avatar
well...
removed the VSS as suggested, cleaned and resurfaced contact area as specified in posted link.
reinstalled original TCM unit
STILL NO LUCK
"s" light on, won't shift out of 3rd gear.....
i'm looking at probably at least $100 to get even a used TCM from a salvage yard.
Do i have any other options?
AS far as a code goes, i'm pretty sure that when i did jumper the connector on pass. kick panel, the s light flashed, but i don't remember the number of times.
Old 05-31-2006, 03:04 AM
read the code and post it here..it will give us a better idea of what is going on
  #17
Old 05-31-2006, 08:57 PM
bgs_daddy's Avatar
Ok, when i put the jumper in the blue connector on the pass side kick panel
turn the ignition to "on"
the CEL comes on and stays on, and of course the "S" light is on as well.
So, what does this mean? Thanks in advance, i appreciate everyone's help/advice so far.
  #18
Old 05-31-2006, 10:02 PM
it means that there is no code stored.........
when there is no code lite will stay on solid when SC ( service connector ) is jumped .
  #19
Old 05-31-2006, 10:44 PM
bgs_daddy's Avatar
so what do i have to do to get a code to show up?
  #20
Old 06-01-2006, 04:13 AM
i can help you trouble shoot the S lite stays on all the time while driving.. but i will be honest with you ,without the proper TCM we could be chasing a ghost.........
like i said earlier ,, i would install the proper TCM your car calls for, clear the computer and see what happens .. and see what happens ..
also,, on your first post you wrote that the ( car shifts perfectly ),, but now you are saying it wont get out of third ???
Quick Reply: 1991 Honda Accord LX "s" light issue.
