1991 Honda Accord Missfire.
Old Jul 12, 2022 | 06:17 PM
Rog195AR's Avatar
Default 1991 Honda Accord Missfire.
My Honda Accord 1991 Automatic starts easy, runs well but seems to misfire when gear is engaged.
Old Jul 12, 2022 | 09:26 PM
When engaging the gear, do you have a misfire when idling, or also when driving?
Old Jul 13, 2022 | 06:01 AM
Rog195AR's Avatar
Thank you for your comments and help.
When idling or revving the engine in neutral there is no misfire.
Only when a gear is engaged, and worse when attempting to drive there is severe misfiring.
If this was a conventional car I would say definitely the problem is the spark plugs.
However with the complexity of the Honda I am seeking information from anyone with this experience before I begin stripping anything.
I have not as yet found a auto mechanic who will work on this model auto.
Old Jul 13, 2022 | 08:50 PM
Any recent work done on your car?
Is the check engine light turning on? and/or the D4 light flashing when driving?
Old Jul 14, 2022 | 12:31 PM
Rog195AR's Avatar
Many thanks for your attention.
No work has been done on the car.
The check engine light is not turning on neither is the D4 light flashing when driving.
I have only driven a very short distance as i did not want to make the problem worse.
Driving is very difficult as there is very little power available as the engine is continually misfiring.
I have checked the self diagnosis system. The check engine light does not blink thus not showing a fault.
Thank you for your help.
Old Jul 14, 2022 | 05:34 PM
When driving the car, does your engine perform better at higher rpms, or does it run poorly at all rpms?
Old Jul 14, 2022 | 06:34 PM
Rog195AR's Avatar
The car runs poorly all rpms.
Thank you fo your perseverance.
Old Apr 27, 2025 | 06:39 PM
1991_accord_EX's Avatar
I have the same symptoms on my 1991 Accord. In Park or Neutral engine is smooth. In drive gears or Reverse lots of vibration, misfires? and low power delivered to wheels.
190,000 miles. Always the vibrations at stops have been bothersome unless in neutral or park. This is a whole other level.
Old Apr 28, 2025 | 12:48 PM
To make this thread less confusing for future readers, start a new thread. If you can answer some of my questions in the post, that would help. Also post if you had any work done or other issues with the car not long before the misfire started in the new thread. Did you fill up the gas tank right before this happened?
StPat
Feb 4, 2013 12:25 PM
dannyelmejor
Apr 6, 2009 10:12 AM
eband00
Dec 29, 2008 01:55 PM
tntmurda
Dec 24, 2008 07:32 PM
tedog1985
Jan 5, 2006 06:43 PM
