1991 honda accord problem
Old Jun 5, 2011 | 08:35 PM
prasadrr's Avatar
Default 1991 honda accord problem
so i have a 1991 honda accord. it used to work, but not sure what the problem is. it has a new alternator, and new battery. apparently, whats happening is the car itself, for some reason, is not getting juice from the battery.. i hear it is an electrical problem, but more details would be nice. please help me out, and lmk what it wud cost to fix it.
Old Jun 5, 2011 | 08:42 PM
Will you tell us what happens when you turn the key to start the car?
Old Jun 5, 2011 | 08:52 PM
Tek310's Avatar
check your fuses9under hood and inside), follow your battery ground wire, make sure it is intact to the chassis.
Old Jun 5, 2011 | 09:50 PM
prasadrr's Avatar
it doesnt even make a sound when i try to start it
Old Jun 5, 2011 | 10:01 PM
Tek310's Avatar
i just recently had a prob like this with my wifes cavalier. ground wire on her ignition switch came loose.
take apart your steering wheel column. inspect your ignition switch.
Old Jun 5, 2011 | 10:31 PM
Do the interior lights turn on? Does the check engine light do the bulb check?
Do you have a volt meter? Use it to see if the small wire going to the starter gets 12V when you turn the key to start the car.
Old Jun 6, 2011 | 04:10 PM
prasadrr's Avatar
no, no lights or anything turn on.
Old Jun 6, 2011 | 04:36 PM
You want to check that your connections from the battery to the fuse box are ok. If you have a volt meter, you should test for voltage on the red wire from the battery going to the fuse box.
Also, use a 10mm socket to tighten down the clamps of the battery cables on the battery posts. I used a 10mm wrench, and I thought that I got it as tight as possible. The wrench didn't tighten down the whole way to ensure a good connection.
CB7-SE-1991
Jan 29, 2013 04:45 PM
thefez510
Jul 2, 2010 12:17 AM
vynum
Jun 6, 2010 08:29 PM
Xavior
May 15, 2010 05:13 PM
TropicalPants
Jan 4, 2010 10:04 AM
