1991 Honda Accord Will Not Start
Old May 9, 2013 | 06:31 PM
Brandon Hicks's Avatar
Default 1991 Honda Accord Will Not Start
Recently my wife's 91 Honda Accord EX would not start. I thought it might be the battery. Took the battery and had tested and there was a dead cell. After replacing the battery, the car was still not starting. So it led me to believe that it would be the starter. We took the starter off and took it to the local auto parts store and had it tested. The starter was still in good condition and worked. Starting to think that is it is the ignition starter switch but after reading some things on Google I am not so sure anymore. Any help with this problem would be tremendous. I am new to this forum so please be kind. It you have any questions just ask I will try to answer them to the best of my knowledge. Thank you in advance for your help.
Old May 9, 2013 | 06:45 PM
First....Welcome to HAF. Next, I and many others do not like "flaming" and will not let it happen....at least until they kick me off
Please create a signature and put your car info in it...then be sure to set the option to display your signature....see mine as an example.
Is this an auto or manual trans car?
Do you have a test light or volt meter? If so, the small wire to the starter (forget the color right now - BLK/WHT ?). When you try to start the car....what is the voltage on this wire?
CB7-SE-1991
Jan 29, 2013 04:45 PM
usafshelley
Jun 1, 2011 10:46 PM
georger09
Oct 1, 2010 01:31 AM
MadNoys
May 11, 2009 03:06 AM
Sliom001
Mar 28, 2006 06:57 PM
