1991ex hvac temp control
Old Sep 1, 2011 | 09:08 PM
wesley64's Avatar
Default 1991ex hvac temp control
a friend of mine has stripped his temperature selector dial.the **** is fine and i have freed up the water valve.apparently last winter he forced the dial and it stripped.the dial will pull the cable in and rotate the valve,but it will not push nthe cable out.
is there a diy for a repair,or some photos,or could some one advise me on a fix?
thanks
brett btw i have a 91 and 92 ex and exr respectively,but have never had the **** strip
Old Sep 1, 2011 | 09:15 PM
If like the 5th and 3rd gens, there is the shaft into the controls. Pull the ****, then the shaft and inspect the splines on the shaft. Of course I'm sure you know there is more than one cable "in play" here.
Old Sep 1, 2011 | 10:46 PM
dgLX2k's Avatar
Where is it stripped? Is it the **** you physically grab and turn that is stripped or is it the internal shaft it rides on that is tripped inside the mechanism. If it is just the **** you grab, might be easy to replace, otherwise, you could drill a small hole through it and the itnernal shaft and put a roll pin in or similar.
Old Sep 2, 2011 | 06:18 PM
wesley64's Avatar
it is the shaft that is stripped
brett
Old Sep 2, 2011 | 06:29 PM
Sounds like you need a new shaft...bone yard?
The next question is why did this happen? Have you checked the blend door and the heater control cables for free movement?
Old Sep 3, 2011 | 08:46 AM
wesley64's Avatar
i have since freed up the water valve but he told me that he forced the knod when the valve was stuck.is it possible to change the shaft without pulling the control unit out?
brett
Old Sep 3, 2011 | 08:58 AM
I know the shaft for the 5th gens comes out, I had the plastic know brake, went to pull it and the metal shaft came with the plastic ****....
Old Sep 3, 2011 | 11:10 AM
The actuator wire is single push/pull wire. If valve was jammed and wire was shoved, it probabaly bucked and bowed somewhere. You'll need to inspect wire and linkages for damage. I had this happen on a toyota celica, but was able to straighten the wire and get it to work.
NemoDat
May 21, 2015 06:05 PM
cxm475
Feb 17, 2012 02:35 AM
DaIna-Kelela
Oct 30, 2009 01:55 AM
raf105
Sep 28, 2007 02:55 PM
jasonsjwou
Sep 11, 2006 07:33 PM
