1992 accord abs problem
Old Jan 25, 2014 | 08:19 AM
rickyacc's Avatar
Default 1992 accord abs problem
hi
i have a 1992 accord which is a 2.2 4 wheel steer model, i have an abs light, and the problem is the rear ones, can the abs sensors be repaired or where can i find decent used ones?
thanks
Old Jan 25, 2014 | 08:35 AM
I found wheel speed sensors on ebay.
It's worth checking for debris on the wheel pulser ring and sensor tip. Debris (rust, grease) can degrade the signal and cause the wheel sensor signal to degrade and set a dtc. I used a rag stuffed in sensor opening to clean tone ring when wheel is turned.
quint2
Aug 21, 2017 08:28 PM
93Accord2.2
Nov 7, 2013 07:10 AM
jroe_28
May 11, 2008 08:11 AM
cyurgeles
Jan 21, 2006 10:36 AM
Joshporsche
Jul 19, 2005 06:23 PM
