1992 accord LX sedan trans problem?
Old Apr 21, 2008 | 11:34 AM
jroe_28
Default 1992 accord LX sedan trans problem?
Not sure if I am in the right place, but I have a question about my car.
It seems as thought the car is not shifting into overdrive all the time. No lights or warnings are on. Fluid level seems to be ok( I think that it is a little more than it should be). The car is a automatic. It shifts normally into all gears just (sometimes) won't go pass fourth.
Old Apr 21, 2008 | 11:57 AM
sir_nasty's Avatar
Default RE: 1992 accord LX sedan trans problem?
does your car have an OD switch?
Old Apr 21, 2008 | 12:05 PM
jroe_28
No, the reason I think that it has OD is b/c I went for a drive and the car was running between 2k and 3k on the rpms at about 60-80 mph. On the way back hme the car was running 25k at 60-65 mph.
Old Apr 21, 2008 | 12:13 PM
sir_nasty's Avatar
Unless I am misreading your post you said that from 60-80 you run 2000-3000 rpms and at 60-65 it was running 2500 rpms? That would appear to be a difference of about 500 rpms at 60 which can be the difference of a 5 mph headwind or tailwind....
Old Apr 21, 2008 | 12:20 PM
jroe_28
First drive would have been with the wind and then on the way back( when I noticed the "problem") I would have been against the wind. Would the wind cause that much difference in the rpms, it was not that windy out in Houston. Maybe I am just crazy???? I have not driven a 4 banger in quite sometime. I own a gas guzzling SUV.
Old May 10, 2008 | 10:51 PM
Rayman4449
Sounds like what you're talking about is the Auto trans lockup not engaging. I'm having the exact same problem on my 93 Accord LX with 162K on it and am here trying to look for a common cause. Sometimes it works and engages as it is supposed to and others it never does so the RPMs are higher than what they should be for a given speed.
Anyone ideas on what would cause this to be intermittant? Is this a common issue with this year range?
Raymond
Old May 11, 2008 | 08:11 AM
Suggest checking Trans Control Unit (TCU) to see if a code is stored. Some codes doen't cause the S or D4 light to flash. Several (3, 6, 11) of them have symptom (LU clutch does not engage). Code 6 seems promising (fault is open in shift position console switch circuit; wiring, coupling, or switch).
Easiest way to get TCU codes is pull back pax side carpet, turn keyswitch ON, and read the LED through clear window just right of center on the ECU/TCU module. Flashes are same code as ECU, long flash, F=10 and short flash, f =1 (ex F-f=11).
newbieny
Oct 22, 2009 05:17 PM
94exsedan35094
Oct 19, 2009 01:58 PM
Jeff020202
Jul 18, 2009 01:50 AM
emaxxman
Mar 8, 2006 09:12 PM
Joshporsche
Jul 19, 2005 06:23 PM
