1992 Accord, idles slow, leads to stalling
Old Oct 14, 2011 | 08:25 AM
Wildcat92's Avatar
Default 1992 Accord, idles slow, leads to stalling
My car has idled rather slowly as of late when sitting at a light, stop sign, etc. Sometimes it idles slow so the oil pressure light flickers, not that thats the actual problem, but as if the car is about to stall out. If I add back in a few hundred RPMs of throttle, it stops the flickering. Today when I put the car in neutral, it idled slow enough to stall two separate times. It starts right back up but clearly this is a nuisance. Any thoughts?
Old Oct 14, 2011 | 10:00 AM
Is the check engine light on? If yes, then get the codes using DIY forum guidance and report these.
If no codes, the problem is likely a clogged idle air control valve and dirty throttle plate/body. See DIY forum for guidance on removing/cleaning the IACV. Different year, but procedure is same.
Clean throttle plate, both sides, and bore around throttle plate w/ throttle body cleaner and old toothbrush.
There is a download 91 Accord manual in Online Manuals post of DiY forum that should be helpful.
Old Oct 14, 2011 | 11:09 AM
Wildcat92's Avatar
The check engine light is NOT on. Ill try the IACV thing that you suggested. Im gonna inspect the throttle on monday. I was going to attempt to tighten the throttle cable so it revs a little bit faster, I know thats not hard, but is that foolish?
Old Oct 14, 2011 | 01:33 PM
For the idle control to work properly, the throttle has to close completely. So you want the cable to go slack just a bit. You can remove excess slack, but don't attempt to increase the idle by tightening the cable.
Look in the DIY section for a post by me about setting the BASE idle.
If you clean the IACV, you might as well also clean the FITV.
CarConfused
Sep 12, 2012 11:40 AM
POS-Accord92
Nov 7, 2011 06:50 PM
Lily2Maine
Dec 23, 2010 01:09 PM
lordsusanoo
Aug 11, 2010 11:59 PM
Accord Pete
Jan 31, 2010 02:50 PM
