1992 Accord transmission CEL Code 30 and 31. help!
Old Sep 27, 2012 | 12:51 PM
slavbrod's Avatar
Default 1992 Accord transmission CEL Code 30 and 31. help!
I have a 1992 honda accord automatic with transmission problems. I swithced out the tcm, no fix checked solenoids (all clicking). I am getting a cel code of 30 and 31. I have the description for theses codes (below), but I do not understand what this means. Please help.
Thanks,
CEL Code 30 and 31 description:
A/T FI Signal A Low Input
A/T FI Signal A High Input
A/T FI Signal B Low Input
A/T FI Signal B High Input
Old Sep 27, 2012 | 07:10 PM
I don't see a code 30 or 31. What light is flashing the code (check engine, D4, or S light)?
Old Sep 27, 2012 | 09:38 PM
slavbrod's Avatar
it is the check engine light. here is a link with codes
90-93 accord and obd1 cel codes.... - Honda-Tech
look at cel code 30 and 31.
thanks,
Old Sep 27, 2012 | 09:44 PM
I misread your post. Those are check engine light codes.
Looking at the diagnostic tree, there are some electrical tests you can try. The tree ends with either fixing a wire or replacing the ECU. It will probably end up being the ECU (not the TCU).
Google 62sn700 pdf
That is a manual in pdf form for a non-us (I think) 1993 accord. It should be pretty close for troubleshooting to see which wires to test, etc..
Old Sep 27, 2012 | 10:01 PM
slavbrod's Avatar
Thanks. How do i get this manual 62sn700?
I am not too good with computers. Do I type this into a google search?
Old Sep 27, 2012 | 10:11 PM
Here is a link to the file.
http://rapidshare.com/files/346513877/62SN700.PDF
Just click on the green download icon in the middle column.
Old Sep 28, 2012 | 07:26 AM
slavbrod's Avatar
thanks much.
Khai Son
Mar 14, 2012 11:32 PM
tdsilk
Dec 18, 2010 06:51 PM
tingjunkie
Sep 17, 2010 06:37 PM
Stener75
Jul 25, 2010 08:21 PM
rdrx7
Aug 25, 2009 07:49 PM
