1992 Honda Accord CEL issue
Old Dec 16, 2010 | 11:37 AM
tdsilk's Avatar
Default 1992 Honda Accord CEL issue
Hello,
I have a 1992 Honda Accord Ex where the CEL only comes on when driving. Takes about 1-2 mins before it comes on. What's strange is when I start the car and let it idle (sometimes up to 20 mins or more) the light doesn't come on. Any ideas on why this happens? Also, the car needs to be inspected and I was wondering do they let the car idle during the inspection or accelerate the engine?
Thanks,
Troy
Old Dec 16, 2010 | 11:58 AM
CEL turning on means engine computer detected a problem. To find out what the computer detected, read the code(s). I wrote a thread called how to get CEL codes in the main DIY section that will tell you how to do this.
Old Dec 17, 2010 | 08:22 AM
tdsilk's Avatar
I was able to get the code using PAhonda's method. The code is a code "12" which appears to deal with the EGR system. Any ideas on this would be most helpful.
Old Dec 17, 2010 | 09:27 AM
Based on the 95 procedure, you should pull the 7.5 amp backup/radio fuse to reset the ECU. See if the code returns. Make sure that you have the radio code.
Next, you should pull the vacuum line off of the EGR valve and feel if there is suction when the engine is idling. The EGR is number 18 in the pic below. There should be no vacuum on it when the car is at idle.
Old Dec 17, 2010 | 10:33 AM
tdsilk's Avatar
Thanks for the quick response. I will give it a shot later.
Old Dec 18, 2010 | 01:24 PM
tdsilk's Avatar
I reset the ECU and I the CEL came back on, but this time it took longer. It usually comes on after about 2 mins. of driving, but this time it took about 10 mins. I will try to see if there is any vacuum from the EGR.
Old Dec 18, 2010 | 05:05 PM
tdsilk's Avatar
Pulled the number 16 hose off and there is no vacuum. Any other ideas? Should I try removing and cleaning?
Old Dec 18, 2010 | 06:51 PM
If you have some rev up the engine when the car is warm, that hose should pull a vacuum. If not, I would check the vacuum hoses on the EGR system. There should be a routing diagram under the hood, so you can trace and inspect the hoses.
If you have one of those hand held vacuum pumps, see if the EGR valve will hold a vacuum.
96hondaaccord
Aug 27, 2014 08:29 AM
slavbrod
Sep 28, 2012 07:26 AM
tdsilk
May 5, 2011 04:03 PM
rhythmless
Nov 22, 2010 07:19 PM
imabadczech
Oct 24, 2010 07:24 PM
